Refrigerator side doesn’t get below 45. Freezer works
Redfrigerator make/model
Samsung RS22HDHPNBC/AA
The fridge is about 6-7 years old
Freezer works fine. It gets down to -1. Refrigerator only gets down to approximately 50 degrees. According to the display it thinks the refrigerator gets down to 37. I’ve checked it with 2 non contact thermometers, a volt meter thermometer, and a refrigerator thermometer with the door closed overnight.
Tested old fridge fan with 12 volts. It ran.
Replaced:
Control board, refrigerator thermister, and then the refrigerator side fan.
Checked:
Power supply board. All output voltages are good.
Door switches work. Verified that the fans come on and lights go out when door is closed.
Freezer and refrigerator evaporator coils- neither are icing up and both are clean. Only a little frost on the bulb.
Cleaned condenser coil and fan. Compressor and condenser fan both work.
Even though it wasn’t frozen I did a complete defrost and cleaned out the refrigerator.
My wife tried checking the refrigerator for fault codes but it didn’t have any.
I tried running a fan in the refrigerator with the condenser coil cover open. I was able to get the refrigerator down into the 20’s this way. I’m running out of ideas. Any advice?
Questa è una buona domanda?
