Salta al contenuto principale
Repair guides and troubleshooting for Presario CQ58 series. These are budget laptops made by Compaq, which was owned by HP from 2002 to 2013.
20 Domande Visualizza tutte
Why is my computer so slow?
When i boot it up it will take a while to load and it take 2 min to load up the taskbar and it’s so slow at everything so can someone please help me???
I have tried to factory reset it and and get a lot of anti virus
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @jonathanm52184
What is the full model number of the laptop as shown on the information label on the bottom of the laptop?
How much ram is installed?
What OS (Win7, Win8.1, Win10) is installed?
Does the laptop have an SSD or a HDD installed for storage?
Your laptop is showing its age. Last version of a CQ58 laptop was released in 2013.
You can only improve performance so far by increasing the amount of ram (model number needs to be known though) and also if there's a HDD installed by upgrading to an SSD.
Other than that you may be limited as to what more you can do.
Depending on the exact model you may be able to upgrade the CPU but maybe not and then if it is a removable CPU and not hard mounted, the upgrade choices may be limited by the motherboard's chipset model and BIOS version as they may not be compatible.
Punteggio 1
7 Commenti:
It has 2gig of ram win 10 has a hdd
da
@jonathanm52184
For best performance in Win 10 you need at least 8GB of ram or more, but the full model number needs to be known to find out if it can be upgraded successfully or not
da
There is no labal
da
@jonathanm52184
Here's a link that may help to find out what model it is.
da
It is a bf9WM
da
Mostra altri 2 commenti
Aggiungi la tua risposta
Jonathan. M sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 226
