Laptop won’t power up
The light on the power button will flash, but it will not power up.
Questa è una buona domanda?
Does it start OK with the charger connected, you didn't say?
If it still won't start with the charger connected try a power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
Here’s the maintenance and service guide for the laptop series (you didn't specify the full model number but it still should be relevant). Go to p.33 to view the necessary pre-requisite steps and then the procedure to remove the battery.
c). Press and hold the laptop's Power button for a full 30 seconds and then release it
d.) Reconnect the battery.
e). Reverse the above to re-assemble the laptop.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 64
