My laptop battery is getting down.Any solution?
My laptop battery is getting decreasing fast.I need solution about it. Kindly comment on this information.
Questa è una buona domanda?
Hi @sohammaity
Create a battery report to find out the charge status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value and check what percentage the Full Charge value is of the Design Capacity value. If it is <40% you should consider replacing the battery.
If you determine that the battery needs replacing, here's the maintenance and service guide, taken from this support webpage for the laptop model.
Go to p.35 to view the procedure to remove/replace the battery.
At the top of p.35 you will find the part numbers for the 2 compatible batteries that may be used in the laptop. Search online using the part number only, to find suppliers that suit you best.
To replace the battery with a new battery is the fast way.
Well I will suggest you to replace your old battery with the new battery this the best solution to issue which your facing.
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 50
Tutti i Tempi: 372
