Salta al contenuto principale
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
157 Domande Visualizza tutte
Should I replace the whole bottom board or just the charging port?
I recently damaged my controller's charging port and I see that the replacement will be very difficult as I've also lifted a trace that sticks solder into a bottom anchor point. I tested the same controller with a charge and play battery and it works perfectly, except for the destroyed port
Questa è una buona domanda?
Punteggio 0
1 Commento
Can you add pics of the board?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
That depends on how confident your are in your soldering skills and your ability to do a stable rebuild of whatever was torn up. It's definitely less expensive, but is not a repair I would have a soldering novice try.
Punteggio 4
Aggiungi la tua risposta
Raptuno sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 18
