Salta al contenuto principale
Western Digital (WD) Solid State Drive (SSD) Available in 2.5” 7mm and M.2 2280 models 120GB or 240GB
The ssd is not showing up
The SSD is not showing up when connected to my PC. It has a lot of data in it. I had used it for transferring data. But now it is not showing up when connected to the pc. No drive is found.
Questa è una buona domanda?
Punteggio 1
1 Commento
SSD card not showing in my PC. The SSD card is ok or not ok. Pls advice. What to do? What is the solution
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Well The BIOS will not detect a SSD if the data cable is damaged or the connection is incorrect. Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
Punteggio 1
1 Commento:
but it can detect my other SSD
da
Aggiungi la tua risposta
thrippakulath unnikrishnan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,493
