Salta al contenuto principale
A sports car made by Toyota from 1992-1995. It has a 1.5 liter inline 4-cylinder with a 5-speed manual or 4-speed automatic transmission.
Can I replace rear 6 ohm speakers with 4 ohm?
I'm replacing the rear speakers in my car and the factory ones say 6 ohm. However its much easier to find 4 ohm. I'm looking at some cheap ones on amazon rated for 30rms, the original say 15w on the back so I assume that is the rms for the factory ones. Could this damage the radio (still going to be using the factory stereo) or should I be safe? I don't know anything about speakers.
Questa è una buona domanda?
Punteggio 1
3 Commenti
2E DX Carburetor and Engine Services
da
1986 2E DX Carburetor and Engine Services
da
@muhabasultan are you talking about a Toyota Corolla are are you speaking about some speakers? What is it that you are needing help with?
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @carsman248
Not a good idea.
There is a risk of hardware damage to the amplifier in the stereo system. Connecting speakers which have a lower impedance than what the amp is rated for, may cause damage to the amp.
At the very least the sound will be distorted.
Punteggio 1
2 Commenti:
Then what should I do? Would it be better to use 8 ohm? Or do I have to find some 6 ohm?
da
@carsman248
Find some 6 Ohm speakers.
Using 8 Ohm won't be good either.
It mightn't damage the amp but the sound won't be good.
da
Aggiungi la tua risposta
Maxwell sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 45
Tutti i Tempi: 1,008
