Salta al contenuto principale
Guide di riparazione e supporto per il sistema operativo Windows 7, rilasciato da Microsoft nel 2009.
How can we fix Operating system not found'
When i turn on i see he says operating system not found
Questa è una buona domanda?
Punteggio 1
1 Commento:
@jasmeetsin53641 let's start at the beginning. When you turn what on? What device are you referring to? I suppose it is a computer. What have you checked? Did this happen all of a sudden or were you working on something? The more history and background that you provide, the greater your chance of getting a good answer.
da
Aggiungi un commento
1 Risposta
Well you can try the following.
  1. Check the BIOS. You need to check for two things in the BIOS.
  2. Reset the BIOS.
  3. Fix the Boot Records.
  4. Enable or Disable UEFI Secure Boot.
  5. Activate the Windows Partition.
  6. Use Easy Recovery Essentials.
  7. Reinstall Windows.
Punteggio 0
Aggiungi la tua risposta
Jasmeet singh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 16
Tutti i Tempi: 412
