Salta al contenuto principale
First released in February 1993, the PowerBook 165c was Macintosh's first laptop to feature a color screen. It also included 4MB of RAM, an 8.9in display, and a floppy drive.
3 Domande Visualizza tutte
PowerBook 165C display ribbon broken
Hi, I have PowerBook 165c.
The system runs, but I can’t see nothin because the video ribbon is broken.
So, apparently there is no way to connect it to external display (am I right ?) so how can I find and replace the broken ribbon ?
Thank Fabio
Questa è una buona domanda?
Punteggio 0
1 Commento
hi Dan , thanks a lot for the answer.
I'm sure the ribbon cable is a problem because.... it is broken.
I'm looking for a substitution but it's very hard.
I checked TheBookYard - PowerBook 165c but it is (for the moment) out of stock. For the external connection, any idea to where I could find such an adapter?
thanks again fabio
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The ribbon cable can be replaced, review this guide Macintosh PowerBook 165c Display Replacement
Are you sure the issue is the ribbon cable? This series used CCFLs to light up the LCD screen, I’m suspecting that’s the real issue as it was quite common.
Take a flashlight pressed on the screen at an angle do you see a faint image of your desktop icons? If you do the backlight circuit will need to be checked out as well as the CCFL lamps.
Here’s one source for parts TheBookYard - PowerBook 165c
As far as connecting an external display, that is possible! Your system offers a mini DB15 connector. You’ll need a special adapter cable to convert to VGA or composite video
Review the EveryMac specs for this system here PowerBook 165c Specs
Punteggio 1
2 Commenti:
thanks again fabio
da
@fabiogiorgetti - Did you ask them for the adapter?
Sadly, the issue a dead system is needed to salvage the parts. Look on eBay for a junker is the last option. Just be careful! There’s a lot scammers out there!
da
Aggiungi la tua risposta
fabio giorgetti sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 77
