Salta al contenuto principale
La quarta generazione di Honda City (la seconda come berlina) ha fatto il suo debutto mondiale al Thailand International Motor Expo di Bangkok nel novembre 2002. Lo sviluppo del veicolo è continuato a essere gestito da Honda Thailand.
RPM is high and its keeps blinking afterwards
When I start my car, the RPM is already high, then when I am on my way, the D icon on my dashboard will blink and it will blink until you turn off the engine. The car sometimes feels like it doesn't want to accelerate.
Questa è una buona domanda?
Punteggio 2
1 Commento
Sensor not working
da Condividi
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi @everleenma65479
The light is warning you that there's a problem with the transmission.
Get the vehicle OBDII port scanned and check if there are any transmission error codes shown.
The error code number will indicate the type of problem with the transmission e.g. faulty sensor, gear solenoid etc.
A lot of major auto parts retail chains in the USA will scan the OBDII port for free.
Get it checked sooner than later before more problems are created.
Maybe also check the level of the transmission fluid to make sure that it is OK and also that the fluid looks OK (not dark and burnt looking) and doesn't need replacing etc.
Punteggio 2
I have same problem the issue is your gear oil is low put gear oil and wash the butterfly of car with petrol and also gear transmission problem solved
Punteggio 0
Aggiungi la tua risposta
Everleen Marie Callanta sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 29
Tutti i Tempi: 1,224
