Salta al contenuto principale
Lanciato il 20 settembre, l'iPhone standard di Apple del 2019 ha LCD touchscreen da 6,1" e doppie fotocamere ed è disponibile in sei colori. È il successore dell'iPhone XR.
Sapphire glass camera replacement
Hi everyone! My girlfriend broke her camera lens only two days after having her new iPhone, so I'm looking for the best possible replacement. Unfortunately, I can't seem to find a sapphire glass lens. Where can I find it? I live in Italy but I would be willing to order it from any other country.
I was also wondering what's the best glue I can use. I replaced my iPhone 6s lens many times and I never found the pre-applied double-side tape that effective: it doesn't seem to adhere that well and it makes the camera stick out too much. Is the T-8000 the best option? And do you have any advice on how to apply it in the best way? I want to prevent any water to get inside.
Thank you so much in advance! I hope you're having a nice day.
Erik
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Erik
Here’s a link to some lenses that claim to be sapphire
https://www.ebay.co.uk/itm/324766527523?...
Also here’s a video guide for the replacement
https://m.youtube.com/watch?v=MVBBUQAHpC...
Also as far as I know the best glue would be E6000
Here’s a link to that
E6000 Adhesive Glue
The best way of applying this glue would be to remove all the leftover glass and glue from the slot then clean with isopropyl alcohol to ensure it will bond and set nicely:-)
Hopefully this helps
Any questions please ask
Immagine A clear industrial strength adhesive. Bonds metal, wood, fabric, glass, ceramic, and other surfaces.
Prodotto
E6000 Adhesive Glue
$2.99
Punteggio 1
1 Commento:
I usually order from China and those work perfect. If you can't find anything, i can send you one from The Netherlands including the prepared dubble sided tape, This way you don't need the glue.
DO remove the backcamera, otherwise the lens will be scratched!
da
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 38
Tutti i Tempi: 514
