Why isn't my generator passing current
My generator starts but when I flip the switch for the current it doesn't pass current into the house, the light indicator for the current is working
Questa è una buona domanda?
You have to first check the indicator light at the front of the generator if is not on you we call for engineer to check the avr or brush for you but if the indicator is on that mean you is your house wiring
If the indicator works , probably problem with switch or isolator terminals , connecting ports terminals , please look throughly for any kind off protection like fuse or mcb
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 63
@oluwagbola30129 what make and model is your generator? What have you checked?
da oldturkey03
