Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e sulla soluzione problemi per l'iPad Apple di seconda generazione con Wi-Fi, disponibile con 16, 32 o 64 GB di memoria. Rilasciato a marzo 2011. Identificato dal numero di modello A1395 e EMC 2415. Le riparazioni richiedono l'uso di calore e una leva eseguita con attenzione.
EMC 2328, bootlooped for sometime, now it blinks and won’t charge
Hello people! I don’t know if this was asked, but I don’t know how to search about it, so I’ll write about it. Recently (2 years ago) I tried to turn on my 2nd gen iPad, since the last time I checked it worked. But when I tried to, it kept boot looping and refused to enter the charging screen. Now is too dead he keeps on blinking trying to charge itself but without success… I charged with its charging cable since 2013 and always worked. Do you guys have a clue what is going on? Or why did this happen? I talked with a tech guy, he told me the motherboard can be damaged, but before spending my money I’d like a confront, because I got a feeling something is not quite right about the statement.
The charging cable makes a really weird noise when is trying to charge the iPad
Immagine
Immagine
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
With an iPad this old it could very well be the battery, corrupted software, or as the tech said, a potential board issue. The best way I’m aware of to see if it’s any of these, is to test a new battery. (Also possible if there is some kind of third party software that can test it by plugging into the 30pin or lightning connector) A side note is that certain older iPads before being updated to the latest software(stuck on old software or have missed an update) are essentially bricked without access to the update servers, which are no longer signing updates that old. (They will ping the server and essentially freak out)But my suggestion is to have a repair shop try a battery or you yourself, but it may not be worth the trouble unfortunately. Best of luck!
Punteggio 1
3 Commenti:
@glitch22 Thank you so much, I see what I can… well, they* can do, then. By the way, I’m letting it charging (hopelessly), should I stop charging it? There’s still chipset’s noise coming from the charger..
da
Hmmm 🤔 while not terrible it may be wasted energy. Test some different power bricks. (which you may have already done) Besides that, I’d leave it unplugged haha. Don’t wanna feed a potentially dangerous battery!
da
I'm 50 years old and only know how to do very few things. I'm trying to learn how to use my phone,tablet,inside and out. My back and flawless gate provide unlimited growth potential.
da
Aggiungi la tua risposta
Elena Fichera sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 378
