My door ajar light stays on when all doors are completely shut.
Door ajar light stays on
Update (03/16/23)
It is a astra 2005
Questa è una buona domanda?
It is a astra 2005
Hi @kent29659
What is the year and model of the vehicle?
Sounds like one of the door switches (located in the door jamb of the doors) is faulty. Either the switch contact is not opening when the door is shut or the switch is corroded and there is a permanent earth signal on the signal lead back to the body control module or the instrument panel (depends on model and year).
There are plenty of videos on YouTube that show how to check if the door switch is OK
Hi @kent29659
Couldn't find a video for your exact vehicle, but here's a video that shows what to look for. The principle of operation for the door ajar light is the same for most vehicles. What can differ is the location of the switch and its design etc.
This is what the switch looks like for your model. (supplier example only, there are others online that may suit you better). The trick is to find out which one of the 4 (one for each door) is the problem and hopefully it is not a wiring problem
I had the same issue. I changed the driver side door lock actuator and the problem still existed. I decided to look at the wiring in the door harness. Once I accessed the wires in the door harness, I noticed a pink/white wire has completely frayed and another wire exposed. I purchased 16 gauge wire and re-connected the wires. Problem solved! I believe the wires in the door harness don’t allow for much play and get worn over time with the opening and closing of the door.
Ultime 24 Ore: 33
Ultimi 7 Giorni: 211
Ultimi 30 Giorni: 1,208
Tutti i Tempi: 14,919
