Salta al contenuto principale
Il Coolpad 3300A è uno smartphone economico prodotto da Coolpad Group Limited. Il Coolpad 3300A è stato rilasciato nel 2015 a un prezzo inferiore a 150$.
How to remove the Daughter board?
My charging port seems to have problem with the charger cord. Can I replace the charger port on the Model 3622 a ?
Questa è una buona domanda?
Punteggio 1
2 Commenti
I noticed that this is a different model from the one I have which is a 3622A not a 3300A
da
Thanks but the problem I have with the Coolpad model 3622A is that the screen cannot be removed once you separate the rest of the phone from the screen.
da
Aggiungi un commento
1 Risposta
Risposta più utile
@machanik yes you can. This is the part you need. Follow something this video to get to the board.
Update (03/02/2023)
@machanik yes you are right. Like I said that video will get you to the board. Then you have to remove the flex cables and remove the screws to remove the board. It is actually pretty easy once you are on the inside. If you get stuck on that, post some good pictures of your board, when you have your Coolpad open. That way we can guide you all the way. Aggiungere immagini ad una domanda
Punteggio 1
3 Commenti:
hanks but this video was not the one I'm looking for to remove the daughter board.
da
The model I have is a 3622A. The one feature here is a 3300A.
da
@machanik here is one for the 3622A. Same principle.
da
Aggiungi la tua risposta
Phill Comeaux sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 31
Tutti i Tempi: 408
