Black vertical lines on MacBook display
These lines appear at random, and this text also appears sometimes when restarting... Any ideas what the problem might be?
Questa è una buona domanda?
So you want to get your MacBook Pro out of jail! Sadly, you’ll need to pay the jailer to get your system out.
Your issue is a scanning issue within the displays T-CON logic. This is likely not repairable as it will require deeper skills to locate the capacitor which is failing. I would just replace the display assembly as it’s quicker MacBook Pro 15" Retina (Touch Bar, 2018-2019) Display Assembly here’s the guide Sostituzione Schermo MacBook Pro 15" Touch Bar 2018
@danj Thanks! So just to confirm, are you 100% sure that that is the problem? I just don't want to buy it if it's not the part I need lol
@steury2004 - I’ve seen this before. But to prove it connect an external display which would show a clean image when the internal is messed up.
@danj Good idea, thanks!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 89
