How do I do away with horizontal lines seen on my tv screen?
Questa è una buona domanda?
could be a loose connection inside or might be a dying backlight or inverter. you can check the connections if you feel like opening it up. if that’s not the problem and if it’s worth it to you to fix it you can probably find replacement parts easily and look up the repair/maintenance manual for the repair procedure
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 42
@kelly_jn that will depend on what they look like. Horizontal lines are almost exclusively indicative of a bad panel. We would need to see what you got going on there. Post some pictures of what your screen shows. Aggiungere immagini ad una domanda
We will also need to know your TV's exact model number
da oldturkey03
