MBP Battery stopped charging
(Added Coconut screen shot)
Suddenly my battery is not taking a charge. In "System Info: Battery Info" it shows "battery installed: NO" and the battery status is not showing in the menu bar. MBP works normally with AC power, but shuts down when disconnected. I've rebooted and also reset the SMC - no change. Coconut is not even sensing a battery. I replaced the battery with an IFIXIT battery last May so the cycle count cannot be anywhere near 1000. TIA (MBP 15" Retina Late 2013)
Questa è una buona domanda?
Bingo! This is a bad micro-controller chip within the battery. You’ll need to replace it.
Contact the iFixit store to get a replacement battery under warranty. Sadly quite a few batts from a few sources have encountered this issue as the chip is a single source and had a bad run.
da Dan
