What is tripping the power cycle?
I changed power supply and main logic still getting power cycle. So I slowly started to plug stuff in and out. What I found is the power cycle gets tripped on and off when I plug the flex cables into the buffer board. However right before it starts to cycle on and off I can briefly see a picture with lines through it before turning on and off cycle. Is this the flex cables or buffer board?
Questa è una buona domanda?
@joev1987 not sure what you refer to as the buffer board. How does it power cycle? What exactly happens? When you do see the picture, describe what those lines look like. Thin? Thick? Horizontal? Vertical?
da oldturkey03
@joev1987 my suspicion is that you are referring to the LCD driver boards. Yes, those are the ones that are the prime suspect for this.
da oldturkey03
