Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Changing cooling paste on MacBook Core 2 Duo
I have a question about changing/refill the cooling paste on a macbook core 2 duo. The CPU in my macbook is often very warm when I'm running small processes. I'm thinking about refill the cooling paste, so does anyone know how to refill it?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes it's a good idea to replace the thermal paste when you have a heat issue with your macbook or for heat problem prevention specially if your machine is aging. Once the heatsink and the fan are removed from the mac you should also consider a fan clean up with compressed air. You can also easily open the fan, dust it off and clean the blades with isopropyl alcohol.
For the thermal paste replacement please click these links:
MacBook Core 2 Duo Heat Sink Replacement
Come applicare la Pasta Termica
Immagine MacBook Core 2 Duo Heat Sink
Guida
Difficoltà:
Difficile
45 minutes - 2 hours
Immagine Electronics Skills
Guida
Difficoltà:
Moderato
5 - 20 minutes
Punteggio 6
Aggiungi la tua risposta
Morten Kvisvik Larsen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 30
Tutti i Tempi: 11,835
