Salta al contenuto principale
La versione aggiornata del Nintendo 3DS da parte di Nintendo. Presenta schermi più grandi, una maggiore durata della batteria, una densità di pixel migliorata e un design più curato.
My 3DS is Not Switching On…
I got a 3DS XL from my cousin in the U.S. about 5 months ago. He even gave me his whole game collection. But 4 day back, I kept the 3DS in my pocket in Sleep Mode for a really long time. When I took it out, it was not switching on and seemed dead. So I kept it for charge and left to get a snack and 5 minutes later, I came back and saw the Orange charging light was gone. I readjusted the cable and the light lit up again. Usually after like half an hours charge, you can boot it up whilst it's charging but when I pressed the power button, no blue light lit up and no screen switched on. I started getting confused and set a timer for the charge. As soon as I plugged the charger in and the Orange light lit up, I started the timer. The light was lit for exactly 1 minute and then stopped. I don't know what to do...I tried opening the back and cleaning the battery space and also cleaning the SD Card slot but nothing works. If it helps, the charger I'm using is not the original one my cousin got with the console as i had to change it cos American adapters are not shaped for other countries sockets and there is also a voltage difference. So I bought a new cable of Amazon and it worked nicely. Please help, I really miss that blue light…
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
Have you tried a different battery?
Also if it is only charging at strange angles it probably has a bad charging port
I had a 3DS that had a dodgy charging port and I found that I could bypass the issue by using the dock
If you don’t have a doc here’s a link to a battery and charging port
Battery
https://www.ebay.co.uk/itm/133870715776?...
Charging port(this will require soldering)
https://www.ebay.co.uk/itm/185546561468?...
Here’s a disassemble guide too(this will carry you through the different repairs)
Sostituzione tasto accensione Nintendo 3DS XL
Hopefully this helps
Any questions please ask
Punteggio 2
4 Commenti:
Really thanks...but the problem is that these links are for foreign countries...Im gonna have to go to Indian Amazon and search for the battery.
da
@joeleedope
Sorry about that
If you type in Nintendo 3DS xl battery replacement
And Nintendo 3DS xl charging port replacement
That should give you results:-)
da
I checked but it’s really expensive cos Nintendo doesn’t operate in india…it’s okay thanks for the help tho
da
@joeleedope
Your most welcome
Let me know if there’s anything else:-)
da
Aggiungi la tua risposta
Joel Titus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 148
