My watch does not power on, or charge
Watch will not power on anymore, will not charge either
Questa è una buona domanda?
Hi Nazario,
You've got three main places to look if your watch isn't charging; the charger, the charging cord and the battery. Odds are it's one of those three things in most cases.
You'll want to try a different charger and/or a different charging cord to try and eliminate those as a suspect. If it still doesn't work, the next most likely source of a failure to charge would be the battery. Fortunately, iFixit has both a guide to replacing the battery available as well as selling the battery itself, so if that's the problem, they've got you covered. Here's a link to the guide you'll need to do the replacement.
Samsung Galaxy Watch Active2 Battery Replacement - iFixit Repair Guide
You'll need to order the correct battery for your watch; it appears they come in 40 and 44 mm models so pick the one that fits your watch. The guide has links to both where you can purchase them.
I dont know whether its the battery prob in my smart watch
Hi Pauline,
What have you tried so far? Have you verified that the charger and/or charging cord work or tried a different one?
Ultime 24 Ore: 7
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 186
Tutti i Tempi: 2,979
1 Commento
Have you tried a hard reset?
da [deleted]
