Salta al contenuto principale
Lo smartwatch Apple di quinta generazione, con connettività cellulare opzionale, lanciato il 20 settembre 2019.
Apple Watch display lcd
I try to repair an Apple Watch serie 5 , but some but something go wrong when I try to attach the lcd display to connector , there is a solution for know if is the lcd screen broken or the connector ?
https://drive.google.com/file/d/1Y-9mF3X...
https://drive.google.com/file/d/1eZnVucF...
https://drive.google.com/file/d/1eawCLGr...
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Adding pictures of the back of the screen ribbons and the connectors on the board would help.
da
Thanks Nigel, i have added the photo
da
Aggiungi un commento
1 Risposta
Sadly your OLED display is damaged! It looks like you had a hard time getting it off as the displays edge looks damaged, but the worse is the damaged connector on the backside. It also looks like the ribbon cables are a bit tattered as well.
In any case you need a new display.
Punteggio 0
3 Commenti:
Can you recommend a site where to take the display with advantageous prices?
da
I had tried to separate the touch display from the lcd display…
But if you tell me this, I order new display.
da
@Leonardo Barbieri - You’ll need the full display assembly which includes the crystal, touch & OLED display. These can’t be gotten separately.
Sorry I don’t have any parts source anymore to recommend.
da
Aggiungi la tua risposta
Leonardo Barbieri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 181
