MacBook Pro 16 A2141 No internal Display / external is fine!
Hi folks
The internal screen of my Macbook Pro 16' 2019 A2141 suddenly did not display any graphics or text. This Macbook Pro is running an AMD Radeon Pro 5500M 8GB.
The backlight is OK and I can modify the backlight intensity through the Touch Bar (which also works perfectly)
Resetting NVRAM & SMC did not change anything (except the chimes is now louder...)
If I connect an external HDMI monitor through a Thunderbolt 3 adapter: no picture at all on the external screen which enters into sleep mode.
When I connect my Mac (lid closed) to my Calldigit TS3 (thunderbolt 3) docking station attached to an external screen (through Display port): The mac is displaying macOS' desktop perfectly on the external monitor.
If I open the Macbook Pro lid, MacOS BigSur detects it and the external monitor is automatically configured as my extended screen. (but the internal screen still displays nothing)
I also checked if I was not concerned by Flexgate. Even with a light/torch, I don't see any text/graphics on the internal screen of the mac when I slowly open it (unattached from the docking station and external screen).
I am repairing musical instruments (analog & digital synthesizers & mixing consoles...) I have basic knowledge of SMD micro welding. I own the A2141 system board schematic.
What should I check now to move forward in my troubleshooting, please?
With my preliminary testing, I don't consider the GPU defective: Am I wrong?
FYI:
After this issue appeared I disabled Dynamic GPU switching.
I've installed gSwitch app to set/force the use of the discrete graphic adapter.
This Macbook Pro has only been used at home, lid closed, on a ventilated shelf, and attached to my external display. Never been transported. I also clean the Mac with Wet & Dry wipe. (screen, keyboard and touchpad)
Thanks to the community for any tips & tricks or assistance.
Questa è una buona domanda?
4 Commenti
what is the board number it starts with 820-
da daniel
@tech_ni .Daniel next time I will open my MBP I will look at the model number. Regarding the schematic, I have it for board 820-01700.
My MBP is a 16' 2019 A2141 - EMC3347 with i9 8cores 2.4Ghz / 64GB / 4TB / AMD Radeon Pro 5500M 8GB. Cheers.
da pascalb63
@danj
Running MacOS BigSur on my MBP 16' A2141, I would like to upgrade to Monterey.
I have got an LG Thunderbolt monitor attached to the MBP through a an Apple Thunderbolt v3 to TB v2 adapter.
Can I try to upgrade or do you think I will lose the video signal during the upgrade (after a reboot)?
Many years ago I remember a guy in a service station using an iMac as a Thunderbolt target monitor with an MBP facing a dead screen.
(Please keep in mind that the T-con board is dead so no more display on the built-in Retina monitor.)
Many thanks for your input.
Best Regards
da pascalb63
@pascalb63 - Sorry, had some other stuff needing attention.
Using your system in Clamshell mode (lid closed and using external display, keyboard and mouse/trackpad) you should be fine.
da Dan
