2006 1.4i golf mk1 .does anyone know how to remove the intank filter
Hi guys I have a 2006 1.4i golf mk1 ...does anyone know how to remove the intank fillter....by intank fillter i mean the one located inside the fuel tank after removing float there is a little fillter that sits inside the swirl pot.
Questa è una buona domanda?
Punteggio
0
Tried VW Golf forums for help? Other than dealer or repair shop, service manuals (Haynes, Chilton, Alldata.diy or Mitchell Data) may be your best source of information.
da F Dryer
"Volkswagen specifies that the fuel filter used on gasoline engines is designed to last the life of the car. Replacement is only necessary if the filter becomes clogged due to contaminated fuel or failure to keep the fuel tank sealed." the 1.4i 16V engine should be a Golf V, not MK1.
Since you have the pump etc. already out and working on it, post some pictures of what you are looking at with your question. You will need to go to edit your question and use this guide Aggiungere immagini ad una domanda
da oldturkey03
