My Problem is my laptop sometimes not starts without plug in
My laptop sometimes do not get started , or get switch on without pluging it in to the switch .
Questa è una buona domanda?
Hi,
If you can start the laptop OK when using the charger, create a battery report and check the status of the battery.
When you have the report, find and compare the Design Capacity value versus the Full Charge Capacity value. For a good battery they should nearly be the same value or you can work out the status as a percentage i.e. Full charge capacity value x 100 ÷ Design capacity value to see what the state of the battery when "fully charged" really is.
If it is <40% you may have to consider getting a new battery.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 87
