Salta al contenuto principale
A2115 / 2020 / Processori da 3,1 GHz a 6 core i5, fino a 3,8 GHz a 8 core i7. Lanciato sul mercato il 4 agosto 2020.
Why time machine backup more space I need?
Tried to use my new iMac desktop and transferred all my data and app from the old MacBook Pro laptop. Used time machine to do a full backup on my external hard drive, and it shows the backup size is less than 100GB. Then use “migration assistance” tool to do restore on iMac, but shows not enough space for restore. I have 250GB storage equipment on iMac and have a fresh Monterey installed, so, it should be well enough for this migration, right? I tried to use Diskwave tool to check library further and found “one drive” reported over 169GB space occupied, that’s weird as this is online app, it should not use my local hard drive space, isn’t it? I then exclude it in time machine menu and redo the back up, however, it still reported the same error. I attached some pictures I took, can someone give some clue what I could do wrongly here? Many thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Try putting your data on an external hard drive and plug it in to the new iMac u can acssess the data externally or just transfer it all! Good luck!
Punteggio 0
1 Commento:
Yeah, I can do data restore manually in this way, but my question is still, why "One drive" occupies space on local drive, and why I can not exclude it from backup on time machine?
da
Aggiungi la tua risposta
Tom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 252
