Washer leaking during cooler weather
My washer is in the garage and leaks from the bottom as temps fall below 50. What would cause this? I ran a rinse and spin cycle with the back off and did not see any leaks and there was no water on the floor but the temp was above 50.
Questa è una buona domanda?
Punteggio
0
Hi @dlayoung,
What is the model number of the washer?
Cold contracts metals so it may be a seal is not waterproof anymore. As it warms up it may seal properly again. Just a guess.
When the temp is <50°F run a rinse/spin with maybe some food colouring in the water and check if you can see the stains anywhere from where it may leak.
Try to feel if anything was wet that shouldn't be, since you didn't see any signs of water.
da jayeff
