Washer filled up with water, but now it won't spin. Kenmore 400
Washer filled up with water, but now it won't spin. Kenmore 400, model 11029422801.
None of the cycles work. Washer is almost full of water. Can't get it to start, spin, drain, nothing. If I force the dial and turn it while holding it in position to in between the full load and medium load selection, it will start to fill again. I only did this for a second so that it doesn't over flow. Is this the symptom of a bad lid switch, 8318084? Figured I'd try that first.
Update (10/16/2022)
See attached image. With timer in wash position there is no continuity between the two prongs circled in white with the timer disconnected from the system. These are where the red and black wires connect. Notice how there are 4 spaces between the 2 prongs. My confusion is if there are 4 spaces between, how can red be pin 7 and black be pin 10?
Questa è una buona domanda?
2 Commenti
@maxmodder yes, seems to be your door switch. See if you can jump it. We would need to know the exact model number for your washer to see if we can find a wiring diagram to remotely assist you.
da oldturkey03
Just jumper the white and gray wire, and it of course needs ground to test. Got it. Thanks!
da Max
