S6 Tablet Lite can no longer connect to my home network, wifi, etc
How can I restore my S6 Tablet Lite so that it can connect to my home network, wifi, etc
Questa è una buona domanda?
Hi @guard102
Is the WiFi turning on and either not detecting or connecting to the network or not turning on?
If it is turning on and detecting the network but not connecting it may be a software problem.
Check if any one of the following resolves the problem:
If turning on and not detecting the network, try using the tablet's WiFi as close as possible to your WiFi router i.e. <10cm and check if it detects and connects to your network OK.
If it does then it may be an antenna (supplier example only) problem or antenna connection problem.
Here's an image from a teardown video for the tablet, showing the location of the WiFi antenna pcb and the antenna cable.
Reset your wifi network settings and after it your problem will be solved.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 96
Tutti i Tempi: 2,180
