Why are my reverse lights staying on even when not in reverse
Questa è una buona domanda?
Hi,
Check if the reverse light switch is OK and is not sticking operated
Hi Christos Karayiannis,
It sounds like you have a faulty or sticking switch for the reverse lights, most likely located in the gearbox. Look at @jayeff answer.
PS! Sorry about my brain conking out on me, and answering about brake lights…
Hi @geirandersen,
Brake light switches usually don't control the reversing lights.
This sounds more like a faulty (sticking) reversing switch connected to the gearbox
Cheers
@jayeff OMG!!! I have no idea what went on in my head… I was thinking of the reversing switch, looking for the reversing switch, but somehow my head “made the decision to barf”.
You are absolutely right; It’s 99 times out of 100 a sticking switch in the gearbox. (I’ll be editing my answer!)
No problems.
Wait till you get to my age. Then you do it so often it seems normal
Cheers
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 185
