Salta al contenuto principale
Modello più piccolo, più sottile e più silenzioso della PlayStation 2 (SCPH-700xx) rilasciato da Sony nel settembre del 2004.
Game won't load
I've tried playing my tiger woods 2004 game and it's says won't read disc, so I bought another one and tried it thinking cd was bad, that one says the same thing. Won't read disc, all my other games work in it.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @darthkylomaul
If it’s not reading disks that usually means that your disk drive is at fault
Before we replace it I would try cleaning the laser as that can cause disks not to read(the laser is found where the disk is inserted and it looks like a little clear window,clean with isopropyl alcohol)
If that doesn’t work I would follow this guide to take it out and see if there is any dust or damage on the inside
Sostituzione unità disco ottico PlayStation 2 Slimline
If it still isn’t working you will have to replace the disk drive
Here’s a link to the part
https://www.ebay.co.uk/itm/144644454924?...
The part is quite expensive so it might be worth looking for a donor console
Hopefully this helps
Any questions please ask
Punteggio 1
Aggiungi la tua risposta
Hasbro sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 12
Tutti i Tempi: 313
