Salta al contenuto principale
Documentazione per la riparazione del controller Dualsense utilizzato con la console Sony PlayStation 5. Numero modello CFI-ZCT1W. FCC ID: AK8CFIZCT1
The ps button on my ps5 controller not responding?
I've opened up my controller and checked to see what it could be. But i do not see any reason why the button is not responding when i put it back together. I have cleaned the the casing the pad and everything the ps button touches but no response
Questa è una buona domanda?
Punteggio 3
19 Commenti
Same, And I doubt someone has the answers, If you’ve fixed it by now I would appreciate if you’d reply
da
I haven't fixed it yet, i still cannot identify the problem. I thought this chat room would help as it is very informative with issues on gaming equipment. Hopefully someone can give me some insight
da
When you plug it in, does the light bar slowly light up orange then quickly flash off one time? If so then it’s the same issue as mine. Can’t seem to find any insight or answers for this. I even tried swapping battery from a known working dualsense; didn’t work.
I bought the Dualsense controller for use with my iPhone, until I can afford a ps5 console. There is even less information and answers out there for people with an issue but no console… please update if you have found anything.
da
@sirswolls Having the same problem as you do after a shell swap, any answers yet or fixes?
da
@gamechan you might need to open it back up.
have you checked that all connectors are fully on?
are any cables torn?
did you damage any components?
could any of the componets have been affected by ESD (electric static discharge)? (you can check by seeing if your workspace is has a sticker or anything like that that claims to be esd safe, or if the table you worked on was completely wood, lol)
da
Mostra altri 14 commenti
Aggiungi un commento
1 Risposta
Risposta Più Utile
Here’s some pictures, unfortunately I can’t add any videos longer then 30 seconds so this is the best I can show for now. But I managed to fix the orange light problem by replacing the battery of the controller.
Punteggio 2
4 Commenti:
i can't see them, maybe this is a me problem tho, lol
nvm i can't see them on anything
da
@timtomissus I'll try something else hold on
da
@gamechan, here's how to add pictures to your answer.
Aggiungere immagini ad una domanda
da
Aggiungi la tua risposta
Munir Umar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 40
Tutti i Tempi: 1,925
