Salta al contenuto principale
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Mac Pro 3.1 RAID card with SSD on system drive
Hi guys,
I have Mac Pro 3.1 and Apple RAID card and I am wondering if will worth to make SSD RAID 0 for system. I am using Mac for photo and video editing and I am not sure if will be any massive performance ?
Thanks a lot for any ideas.
EDIT: I have this one
Questa è una buona domanda?
Punteggio 0
1 Commento
@mayer - Any thoughts? You have more experience on these system.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi
If you can figure out a way to use the pci slots I could see it having a nice benefit in terms of reading and writing speeds
You could get a card that takes 2 m.2 SSDs and raid them together to make a very very quick drive
You will need to take into consideration how much space your pci bus has left as if you already have one raid SSD so you could be close to maxing the pci bus on it and adding more might not have a big if not any increase
Hopefully this helps
Any questions please ask
Punteggio 2
8 Commenti:
I have original Apple RAID card :) so will go with 2xSSD 2,5 in Bay 1 and 2 but I am not sure if it's worth time and effort :)
da
@roboscrap
It really depends on the speeds you get as if you are already getting something like 1700-2000mbps if you add any more you might max out the PCI bus and won’t see much of a difference if not any at all:-)
da
My current SSD have 500 read and 450 write :) so if I go with RAID 0 I should have 1000/900 ?
da
@roboscrap
I can’t say you will get exactly double but I think you could get some Improvement
How much of a improvement,I can’t say for sure but here’s a more in depth video that I think that could help
https://m.youtube.com/watch?v=8VBwuowBnR...
da
@hellomacos Thanks a lot :)
da
Mostra altri 3 commenti
Your normal BUS speed is 3.0 using the bay slots. I've gone with the OWC PCI card to get 6.0 BUS speed.
https://eshop.macsales.com/item/Sonnet%2...
I pulled my RAID card after the battery went dead and I saw the cost to replace it.
It was about $135.00, here how it's done: https://manuals.info.apple.com/MANUALS/0...
Punteggio 1
1 Commento:
And can you remember what was the speed differences ? I mean some real numbers :)
da
Aggiungi la tua risposta
Rob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 267
