Salta al contenuto principale
Documentazione di riparazione per l'iPad Pro 11" di terza generazione (numeri di modello A2377, A2459, A2301 e A2460). Rilasciato a maggio 2021.
top volume button isn't working
the top volume button is stuck. is there any way to fix that?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta più utile
You'd have to remove the screen and maybe, depending on location remove the motherboard too. Then remove the plate behind the buttons to remove and clean them and the opening for the buttons. Unless the area around the buttons has been damaged. If you haven't removed a ipad screen before go real easy as there's a risk you'll break it.
Punteggio 1
1 Commento:
Thank you. Definitely helpful but I’m not that tech savvy. Have a great day!
da
Check your iPhone's volume settings (sound settings) to make sure that volume buttons aren't disabled. To do this: Open the Settings app. Tap Sounds & Haptics
Regards,
Will
Punteggio 0
1 Commento:
Thank you - will try that.
da
my power button is not working well, it is mostly stuck. Can this be fixed?
Punteggio 0
Aggiungi la tua risposta
Pam sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 551
