The camera is not running off battery anymore.
I can’t figure out if its because the camera is not charging the battery or the battery is not giving power to the camera or even if the battery is fully dead
Questa è una buona domanda?
tristan evans if you are using a USB charger, us a USB Ammeter and see if your camera pull some amperage. Unless you have some prior damage etc. I would start with checking the charger. After that the charging cable. Make sure that the ends are clean no corrosion etc. Measure the output of the charger. After that check the charge connector and make sure it is clean, no damaged pins or other debris in it. If all of that checks out, replace the battery first. The re-evaluate and see if you need to dig further. There are usually charging fuse on the circuit boards but for that you have to tear it down etc. Start with the easy stuff first. Here are some guides that will help you to work on it Panasonic HC‑VX870
If in doubt about anything, you can always post some pictures of what you are up against, with your QUESTION,. That way we can see what you see. Aggiungere immagini ad una domanda
Thank you for the help, i have done most of what you have said their, i am currently looking to get a new battery. Finding one is the issue, because i live in ZImbabwe. Lack of a panasonic shop here
@tristan evans yes, batteries are an issue with most of our devices now. Ever since shipping of Lithium batteries got so restricted, it'll get tougher and tougher to maintain those devices. If there is anything I can help you with, let me know.
Thanks for your help i am still working to try all the solutions you mentioned
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 135
