Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
iPhone 7 (GSM) experiencing Error 7 with code 130C.FFFF
After restore from iOS 12.5.5 to iOS 14 iPhone 7 (GSM) got error 7 with code 130C.FFFF, what's the issue? It's seems that's issue is in iPhone itself. When restoring thru 3uTools, it's says "Can't update Stockholm". (btw, Stockholm is a codename for Apple Pay) Could this be modem? Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I have seen this error come up a few times and replacing the homer IC “U3601” fixes the problem. If you don’t have a homer IC you could try re-balling the one that’s on there. I usually get these repairs after someone has tried doing an audio IC or Baseband PMU repair. I guess they have applied to much heat to the board causing the homer IC’s solder balls to become oxidised, cracked or nudged.
Punteggio 3
Updating stockholm
Punteggio 0
U3601 being reason for this error was confirmed today. I replaced Audio IC - following update ended at 69% "Updating Stockholm" with error "Failed to restore device(-1)". I searched online for solution and found this. I reballed U3601, soldered it back and update proceeded successfully.
Punteggio 0
Aggiungi la tua risposta
Leo Yakub sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,544
