Salta al contenuto principale
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 Edge è la versione con schermo curvo dell'S6, il modello al top di gamma di allora.
Why won't my phone turn on?
I don't know what happened it was working a few minutes ago until suddenly it started going a little glitch then I tried to turn it off and it worked so I wanted to turn it on again but it isn't working im charging it right now and I don't know what to do I need this fixed in 3 days.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Y.I.N.E try a power cycle first "There are multiple ways to reset your device if you are experiencing issues. The first step is to power cycle your device. Press and hold the Power/Lock button, then select Power off. Select Power off to confirm. To turn the device back on, press and hold the Power/Lock button until the screen lights up.
Note: If you are unable to power your device off or if it becomes unresponsive, press and hold the Power/Lock button for 10 seconds, until it reboots." If that does not work check through other solutions for a software issue on here If none of those work, you have to dig a lot deeper into the bowels of your phone ;-) Follow this flow sheet to narrow it down. the images are best viewed when downloaded and using your own image viewer.
Immagine
Immagine
Immagine
Immagine
Punteggio 2
2 Commenti:
Thank you for your help but I realized that my phone is just dead since it is a old model and the battery has been steadily declining.
da
@Y.I.N .E just replace the battery and start from there. "just dead" should be an easy fix ;-)
da
Aggiungi la tua risposta
Y.I.N .E sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 15
Tutti i Tempi: 890
