Salta al contenuto principale
The Dell XPS 13 7390 is a compact, lightweight laptop from 2019 that features a 10th Generation Intel Core processor, a 13.3-inch InfinityEdge display (often 4K UHD), and a slim, sturdy aluminum chassis. Highlights include strong performance for its class, Wi-Fi 6, and robust connectivity via two Thunderbolt 3 ports. Critics state it relies heavily on USB-C and lacks a traditional USB-A port. Don't confuse this laptop with the XPS 13 7390 2-in-1, which is similar but has a 360 degree foldable display.
Battery replacement for the XPS 7390 model
I can see you have the Dell XPS 13 9343/9350 Laptop Battery replacement available, will this work with the XPS 13 7390 model? I'm having a !&&* of a time finding a reputable seller and some guidance would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Ifixit gives a 1 year warranty on the battery, which is better than most.
If it doesn't work then at least you will get a refund or a new battery
Scroll down to description and warranty. Also see Shipping restrictions on the page
Immagine Replace a 52 Watt Hour (Wh) battery compatible with select models of Dell XPS 13 laptops.
Prodotto
Dell XPS 13 Battery - DXGH8
$79.99
Punteggio 1
Aggiungi la tua risposta
Kingsley Gittins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 565
