Salta al contenuto principale
Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
Idle adjustment for mower
cannot get mower to idle up. Replaced the spring but will run a while then slowly die unless I manually move idle arm.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You will have to look carefully at the linkages to figure this out. There is probably part of the linkage that hits a stop on the low end and it either going past it or has been bent. Since it is a mechanical governor, the problem might be there.
Punteggio 0
Aggiungi la tua risposta
rcarder sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 29
Tutti i Tempi: 501
