Salta al contenuto principale
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Getting a code F:01
My washer starts then stopes with code F:01 and I don't know how to reset it. Never had any problems with the machine in 5 years.
Model # MVWB450WQ0
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Here's the Tech sheet for the washer.
Run the Automatic Diagnostic Test mode as described on p.1 to verify that the error code is an F01.
If it is then on p.3 it indicates a Pressure Signal Out-of-Range problem - see possible causes.
If the pressure hose is OK go to p.4 Test #3 Motor Circuit to see if you can determine whether the motor or the MCU (Motor Control Unit) is the problem.
Punteggio 1
Aggiungi la tua risposta
reedinbeaufort sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 248
