Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per la Nikon D3300, rilasciata nel 2014. La Nikon D3300 è una fotocamera DSLR entry-level.
Spots On Camera's After Image
Every time I take a photo of a bright surface (usually the sky), dots appear on the after image. There are none when I'm looking through the viewfinder. I thought it might have been the lens, but I tried it with multiple ones. The mirrors in the DSLR don't appear scratched and there's really no visible dust or anything.
My family has had the camera for several years, and this only started about a month ago. It didn't interfere with the quality at first, but now there's more spots and it really bugs me.
Has this happened to anyone else? Is it fixable? If so, does it need professionally repaired?
Thanks for any help.
Examples:
Immagine
Immagine
Immagine
UPDATE: After some more research, it seems like it's dust on the sensor. Best way to clean that?
FINAL UPDATE: It’s clean! After watching some videos, I figured out how to do it on my own. I had previously blown on the mirrors, but apparently I missed a step. To anyone who has this problem, make sure you go to settings and lock the mirror. The one hidden was the issue. I had a kit, but those nose blowers (whatever they’re called) probably work well too.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Check digital camera forums for help. Dustbuster used lightly may blow off dust buildup. A very soft camel hair brush used carefully may help remove clinging dust.
da
Hi Maggie,
Good one! It would be helpful for others if you posted your solution "Final Update" as an "Answer" - cut an paste it into "Answer this question".
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Copy of update since it’s also a solution:
…After watching some videos, I figured out how to do it on my own. I had previously blown on the mirrors, but apparently I missed a step. To anyone who has this problem, make sure you go to settings and lock the mirror. The one hidden was the issue. I had a kit, but those nose blowers (whatever they’re called) probably work well too.
Punteggio 1
Aggiungi la tua risposta
Maggie Kudrick sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 27
Tutti i Tempi: 349
