Salta al contenuto principale
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
What is causing my MacBook to display vertical pulsating bars?
My screen has started to display multiple vertical bars that pulse and disappear every 5 seconds or so. The screen will freeze during the pulse and then functions normal again until the next pulse.
Seems like a physical issue. Does anyone have any recommendations on what to try before I open the MacBook?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Have you tried plugging in an external display to see if the effect is also present on it?
I'm suspecting the display got damaged somehow, a heavy object pressing on the lids bottom edge or a good bang along the edge.
You'll likely need Display Assembly and here's the guide to put it in Sostituzione gruppo dello schermo MacBook Retina 2015
Punteggio 0
Aggiungi la tua risposta
Daniel Sallee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 71
