My fan is making so much sound while rotating, what should be the prob
Fan making sound while rotating
Questa è una buona domanda?
Hi
I would first take it off the ceiling and take it apart til you get to the motor and make sure the baring isn't stuck and spins freely
also while you are checking it I recommend putting some form of grease in it to help it spin
if that doesn't work if the motor has carbon brushes I would check them to see if they look heavy warn as this can cause this issue too
Hopefully this helps
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 48
1 Commento
A description of the sound would be most helpful. Grinding? A sort of squealing or squeaky sound?
da brandon k
