Salta al contenuto principale
Un portatile basato su ChromeOS, prodotto da Lenovo. Dispone di un display da 11,6 pollici, un processore Intel Celeron, 4 GB di RAM e 32 GB di memoria interna (eMMC).
Won't power on
I do chromebook repairs for a school district and I have come across a couple hundred 100es that have a charge light, are fully charged (left on charger for 1 day or more), but don't seem to turn on. I've verified that the battery and screen/topcase are working by testing them on other chromebooks. I've also plugged in an external display and the cbs are not sending any display signal. Seems to be any issue with the motherboard perhaps?
I've tried these troubleshooting steps (aside from verifying the physical components as noted above)
-forcing a powerwash
-draining flea power
-unplugging all connections from motherboard and reseating them
-toggling "shipping mode" on the batteries
Sorta at a loss. Anyone else experience this issue or have a fix ?
Questa è una buona domanda?
Punteggio 0
1 Commento:
I would check the battery’s with a multi-metre to make sure they are charging
If they are t you will have hook them up to a bench power supply and charge them at a low power going into them as we won’t want to damage them do we:-)
da
Aggiungi un commento
2 Risposte
The Lenovo 100e Chromebooks have a problem with ribbon cable flaps not staying in place. Open the bottom of the unit and check the flaps on the ribbon cables of the power board. one will probably be up or not down tight. we place a small piece of electrical tape on them to hold the down.
Punteggio 0
Immagine
please help me fix it
Punteggio 0
Aggiungi la tua risposta
Caitlin Wolf sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 1,065
