Salta al contenuto principale
Il Bose Portable Smart Speaker è uno speaker Bluetooth portatile, wireless e a controllo vocale.
What type of tools needed to open the Bose Speaker
what type of tools needed to open up up tj Bose Speaker
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Hi,
Here's a teardown video that may help.
One of the comments below the video mentioned that the screws on the bottom are a 5 point security torx screw so at a minimum you will need a Torx 5 point tamper proof screwdriver. Unfortunately the size wasn't mentioned e.g. T5, T6 etc
Punteggio 2
3 Commenti:
Thanks so for the vid, I’m looking for the charging unit ? Any ideas
da
@Olu Osibo
If you get an AC/DC adapter with the following specs it should be OK
Input : 100-240 V AC , 50/60Hz
Output : 5V DC 3A
Output plug : USB-C
Here's an example
Of course the adapter's AC input plug design would have to match the wall power outlets where you are so that you can plug it into the wall power outlet ;-)
da
I found the link to the bits that he used in the video on amazon, it’s only £7/$9 here: https://amzn.eu/d/dg8hV9T
da
T8 opens the base, T10 separates the battery and charging port, T6 uses the speaker screws, and after removing the base, the next four screws require hollow Torx screws (T10).
Punteggio 0
Aggiungi la tua risposta
ltgoh5 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 14
Ultimi 30 giorni: 69
Tutti i Tempi: 2,088
