Salta al contenuto principale
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
No cold water on wash but rinse is fine
I have no cold water going into the machine on the wash cycle. Rinse cycle fills just fine with cold. Took hoses off and checked inlet screens—they are fine. No problem with house supply. Anyway like I said there’s cold on the rinse but none on the wash.
Questa è una buona domanda?
Punteggio 1
9 Commenti
Hi,
What is the model number of the washer?
da
Model number is MVWB300W02
It definitely seems like an electrical or computer issue.
da
that sounds like corrosion on the valve not allowing cold and hot water in that or some gunk in there blocking the flow i need more info
da
do u have heavy water or high content of minarels in the water such as calcium, sulfides, or even led cuz that can do the same thing too over time
da
Martha Wright which wash cycle are you using? If it has cold in one cycle but not the other, it is unlikely that this is a water supply issue. This sounds like a wash program issue.
da
Mostra altri 4 commenti
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi,
Here's the Tech Sheet W10374149 Rev A for the washer.
Run the automatic diagnostics as per p.1 and check if a C2 error code occurs. If it does follow what it states in the C2 Recommended procedure section to find the problem.
Punteggio 1
u have a bad or malfunction water temperature switch
Punteggio 0
Aggiungi la tua risposta
Martha Wright sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 221
