Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
90 Domande Visualizza tutte
Why won’t my MacBook stay on unplugged?
I have a refurbished 2019 13” MacBook Air. It’s worked great until yesterday I went to turn it on. It took forever. So I went and cleaned it out, updated and all that good stuff and then it started working perfect again. But then whenever I would unplug it from the charger it would immediately shut off. Now it takes forever to turn back on if it does (still works great when it does finally turn on) last night I got it to chime with the Apple logo on screen twice but didn’t fully turn on and hadn’t turned on at all since. Battery says it’s normal and fully charged. Side note: I had it plugged in the charger for ab 3 consecutive months. Any idea would could be the problem? I’ve tried resetting it. Different keys I saw online to restart it. But nothing has worked.
Questa è una buona domanda?
Punteggio 0
1 Commento
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
This still sounds like it could still be a battery issue to me. The it powers down as soon as I disconnect the charger and then "it takes ages to boot up" is not unusual for that. Does your fan also seem to run really heavily all the time? I might install coconut battery and see what that says about that state of your battery. You can add screen caps to your original post of the results.
It's possible that the leaving it plugged for a long time is related, but I don't think you're alone in doing that and modern versions of macOS are generally pretty smart about charging in ways that maintain battery health.
Punteggio 1
2 Commenti:
Thank you for responding! That’s what I think it is too. This may be a silly question but I’m too non tech savvy lol. To install coconut battery does it have to be on the computer or is there a way to possibly do it on my phone since the iCloud is synced? Since I’m not able to get the computer on to download it there?
da
@olivia1799 - Need to directly install it (macOS App), but you can download the file to then transfer it over from your iPhone.
da
Aggiungi la tua risposta
Olivia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 37
