xbox with a error code 07
i have a og xbox with a error code 07 red and green blinking light both fans are loud DVD drive wont open its says your xbox requires service 07
Questa è una buona domanda?
https://www.youtube.com/watch?v=VSrRaA6M...
This is the fix.
Any more problems ask in the comments of this answer.
From what I have seen, possible causes for this error are a failed hard drive, insufficient voltage to the hard drive, failed/loose IDE cable, incorrect jumper settings on the drives, or even a failed DVD drive in one case.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,863
4 Commenti
Is this an original Xbox?
da Andrew S
@andrewsawesome Yes, og means original.
da NR26
Can you disassemble the Xbox and upload a picture of the circuit board? Aggiungere immagini ad una domanda
da Andrew S
@andrewsawesome I'm not the person that asked this question.
da NR26
