I can’t remove screws from home button
I’m having trouble removing the home button screws, I’ve tried two different screwdrivers and they’re not budging. please help
Questa è una buona domanda?
Two two screws are just Philips #000. Assuming you're using the correct screwdriver and you haven't stripped the screws, a good way to get a tight screw loosened is to actually tighten it a tiny bit first. This "breaks" the seal that the screw may have with its matching thread, making it much easier to loosen and back ou.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 28
